2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-23T18:59:24+00:00
    I'm not sure I understand. Why not use Hibernate? I tried using NEVER, meaning it just never sleeps or hibernates, and the display just goes off whenever you set it to.  But I think then it is still reading and writing to the hard drive intermittently, fan may come on, etc.  Seems better to at least eventually hibernate after non-use for some time.
    Nonetheless, if you use this NEVER method, how would you get the display to turn off like you do with a phone? With the keyboard, I suppose you could use win-L to lock which will turn off display after a while.  But I don't see anywhere to set the power button for Display Off....only options are sleep, hibernate or do nothing.
    2015-12-23T19:24:40+00:00
    > Sadly, it's not just the SP4, but it was happening on my SP3 as well, after I upgraded it to Windows 10.
    Well the silver lining there is that means it's a software related issue, at least on the Surface 3. So we can hope an update will solve the issue on Surface 4.
    2015-12-23T19:36:44+00:00
    I also have the same issue on a UK model. It is deeply frustrating to have to keep forcing a shutdown every third or fourth time it is asleep. It is a very expensive unit and a bug like this seriously affects its usability as far as I am concerned. Very disappointing in what otherwise seems a reasonable product. First time I have bought a Microsoft product and unless its fixed soon may be the last.
    2015-12-23T20:18:30+00:00
    Yes, I defected from Dell to Microsoft for this purchase, even getting the Band 2.  My wife had the SP 3 which has been great.  But now I am underwhelmed by the customer support, which was much better in my experiences with Dell.  Microsoft is reminding me of how the airlines behave; say nothing while you cancel flights, and then act indignant.  Here, Microsoft chimes in now and then, but subsequently disappears.
    I suspect they don't want to jeopardize Christmas sales.  But all those purchasers will be returning them if the fix does not appear in early January.  OF course, it would be nice to see it NOW.
