2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
  1. Deleted
    2015-12-23T11:22:14+00:00
    Thanks for the explanation. I will do this. I like this machine in every way except this issue and don't want to return it.
    It does appear that the machine wakes up from sleep but the display does not.
  3. Deleted
    2015-12-23T18:44:35+00:00
    Sadly, it's not just the SP4, but it was happening on my SP3 as well, after I upgraded it to Windows 10.  That was one of the primary factors in my decision to upgrade to the SP4, and now it's happening here as well...  it is EXTREMELY frustrating, and VERY annoying!  As much as I hate Apple, it really does make me consider an iPad Pro, which really **** me off since this thing costs $ 2,600 !
