2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-22T15:55:58+00:00
    Will it help if I Reset my PC? Are there others who were able to fix it with resetting? Its so unreliable for work,,,, I was so excited to have this device, I had to do a huge risk just to have this device imported here,,, I live here in the Philippines there is no customer support here for return or exchange... 😩
    Wow, when I called Microsoft for tech help, I reached their staff in the Philippines! This topic has gotten large so prior posts may have gotten lost. The "fix" is to use hibernate instead of sleep.  I found that I am not having waking problems with it, but I am bothered about putting it into hibernate when I want to just shut off the display.  Sleep worked fine for that.  So Microsoft needs to fix this, and it would be nice to have a turn display off method without having to use sleep or hibernate.
    2015-12-22T16:15:09+00:00
    Almost certainly not :( It seem recent updates make it worse and you'll have to apply all updates.
    2015-12-22T16:20:19+00:00
    I upgraded to an i7 16 256 and it has exactly the same issues :(
    Straight after performing the initial installation I could open and shut the case as much as I liked and it always woke up at the locks screen. Once all updates had been applied it completely locked up the 2nd time and I can repeat. This is a complete lock up there is no response even with shift to invoke sticky keys. Only long power button press will get out of it.
    Come on Micorosft please get you finger out!
    2015-12-22T16:34:12+00:00
    I was also told also to use hybernate. I don't have any problems waking up after that. I too was excited to have this product, but with all the problems I have had, I am not any more. I waited too long to return for refund. I will not be telling others about the Surface Pro 4.
