2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-09T17:24:11+00:00
    I have had the same problem with an SP4: if the screen turns off automatically, I can't turn it back on again. I have to hold down the power button for 15 seconds to do a hard shutdown, and restart.
    One approach that seems to work is never to let the screen turn off automatically, as mentioned above. Always sleep it using the menus. It restarts easily.
    Another approach is getting onto the Insider Fast track and installing build 10586. I've only just done that myself a few hours ago, and though it's early days it seems to be waking properly for the first time touch wood.
    I also wonder whether setting the sleep timer to be shorter than the screen off timer might help, if it's a screen off problem rather than a sleep problem. I can't test that right now because since 10586 I can't reproduce the problem. :) Touch wood.
    John
    UPDATE: Ugh. Spoke too soon. Had to do the 15 second poweroff again to start it again from sleep. Resorting to klu" build 10586dge #1 until a real solution is found...
    I was going to ask what "build 10586" is but now I don't have to, since it didn't seem to work. Knocking on wood doesn't ALWAYS work, does it? :0)
    I actually had the same type of problem with my old, dying Dell Inspiron, after I loaded Windows 10, so I wonder if this is a Windows 10 issue, not a Surface Pro issue. If I let the computer "sleep" on its own without pressing the "sleep" button it would blank out and I would need to restart.
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2015-11-09T17:36:57+00:00
    Penny,
    If you have to use the two button reset continually, you need to either reset your new Surface (which should never be required on a new machine, but this has resolved issues for some people) or exchange it. If you are near a physical Microsoft Retail Store, go there and they will swap you out.
    2015-11-10T06:32:23+00:00
    Penny,
    OK, I can try a reset, but HOW? I looked up on Internet but only found the information for previous versions, such as Surface Pro 3. Is it the same?
    I don't live near a Microsoft store, sadly. I live in Anchorage, AK and we had to order this Surface Pro from Microsoft. So if I can fix it without sending it back it would be better.
    thanks for your help.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2015-11-10T10:28:27+00:00
    1. Browse to the Download a recovery image for your Surface page.
    2. Sign in using your Microsoft Account.
    3. Select your product and provide serial number of your device if it is not already registered against your MSA.
    4. Download the recovery image and save it to your Surface or another PC.
    5. Create the Recovery Drive following the on screen instructions for prepping the FAT32 USB drive.
    6. Use the Recovery Drive to refresh or reset your Surface.
    Here are the instructions to use the Recovery drive:
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/usbrecovery?os=windows-10
