2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-19T03:08:12+00:00
    You can count my vote as someone that agrees that an MVP Insider response of "return and exchange", which I have seen you post here on multiple threads, is a completely unsatisfactory response
    FWIW, I agree with what you're saying, that customers should not have to do an OS reload right out of the box with a $900+ product, but I had to do that on my Surface Pro 4, and while it was annoying, it has so far resolved most of the problems
    I am also thinking about returning mine but if I do, I am not accepting an exchange. Way too many problems for something that costs almost $2000.
    -sometimes wont wake from sleep without voodoo
    -screen never flickered but does after latest firmware Dec 17.2015
    -display driver crashes
    -wifi always turned off on wake
    -kick stand wiggles after a week
    -type cover trackpad quits
    -type cover track pad loses gestures, scroll etc
    -battery drains unless you use sleep
    -space bar broken all of a sudden and stuck down
    -pen doesnt track sometimes.. Button works
    I love the idea and it's pure joy when it works... But sady owning this thing is just way too frustrating for me.  Its sounding like many are having the same issues.
    It doesnt help that the patches and updates dont come with a change log or release notes... And the forced driver updates are a huge liability.
    Close but no cigar.
    2015-12-19T03:50:11+00:00
    I'm disappointed not to see any media on this: Verge, Ars, Re/Code, etc.
    I see mostly i5/8Gb/256 owners here. Any m3 or i7 units having video problems?  Specifically, is this an Intel HD 520 problem?  Does the Intel Iris unit also freeze?
    Owning up to problems would mitigate our frustration.
    2015-12-19T04:08:10+00:00
    Yes same problem. Freezing and then needs to restart. Try to check which application is eating your memory in Task manager. I was able to fix mine, I disabled the background recording of xbox... Just go to Xbox app and then settings.
    2015-12-19T04:09:28+00:00
    I want to believe these are isolated issues affecting a small number of units... However, it certainly seems to be wide spread not just with the surface line but with anything these days. Some people are on their third unit and still don't have what they thought they were buying.  If the problems crop up early atleast you can return it.
