2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-18T02:41:35+00:00
    Todays new firmware update appears to have fixed the problem, for me at least. I did have one driver crash message, but my sp4 comes out of sleep EVERYTIME now whether the keyboard is folded back, or if I close the lid, hit the power button, etc. FINALLY. Fingers crossed!
    2015-12-18T04:44:23+00:00
    This just happened to me tonight. First time.
    All updates installed as of Dec 17, 2015
    2015-12-19T00:19:02+00:00
    So, we had another update, and at least one person still had a Sleep problem.  Let's assume Microsoft will provide a fix for this....how would we know that is should be fixed now?  Trial and error, or would they announce the fix has arrived, at least on this board?
    2015-12-19T02:24:28+00:00
    They must be afraid to say it's fixed because if it's not, people will be upset.  Or perhaps they still have some corner cases where its still broken.  They clearly want us to guess and speculate which is all we can do since their policy is to provide zero release notes.
    Mine does seem to work better since the update but it's only been one day and my issues are intermittent.  If I'm good for 3 or more days then I'll consider it stable enough for business.  We have to wait and see.  Trial and error is accurate and we are just like QA beta testers only we paid lots of money to do it.
