2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-16T15:43:46+00:00
    I have bought it since last week but I have the EXACT same problem for many times already.
    Microsoft needs to fix it ASAP.
    It is NOT ACCEPTABLE for consumers to accept these kind of errors
    How can a computer needs to reboot every time I got this error!?
    Even a cheap notebook computer will not have this issue
    Certainly MS need to quickly fix this problem
    2015-12-16T15:54:41+00:00
    Agreed.  It's not acceptable.  I just bought my surface pro 4 2 days ago and have had this issue, horrible 5GHZ wifi performance, and issues with the mail app not properly updating its badge number when I remove e-mails which for a $1500 device used mostly for consumption and occasional business productivity (where I'd be using Outlook) is absolutely unacceptable.
    Returning the device today.
    2015-12-16T21:17:15+00:00
    In other forums, I've learned that Microsoft "apologizes" for this bug, and has recommended using Hibernate, not Sleep, in the interim.  Hibernate is a deeper sleep but seems to work better.  My problem is I like to turn off the display manually, used to just push power button set to Sleep.  So now, I hesitate to use hibernate to just turn off the display.
    I also wonder...if Microsoft is truly sorry, why not offer something? Maybe give all of us suffering with this at least an extra power cord?  They have tons of cash, but seem to be acting like the airlines, with no offer of a free drink when flight is markedly delayed.  Do these companies know so little about customer satisfaction?
    2015-12-17T11:28:06+00:00
    I agree. When in tablet mode you want the power button to just sleep to avoid unexpected screen events.
    However my experience is the problem only occurs when shutting the cover so I changed that to hybernate. I feel this is a kludge as sleep should automatically hibernate after a set time - I'm not sure if this works on win10 though. With cover on I want cover close to sleep and power button to hybernate.
