2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-15T17:04:33+00:00
    Test 4.  Keyboard attached (folded behind the tablet).  Power on from Hibernate Result is UNACCEPTABLE
    Here is another thread that discusses the folded keyboard issues:
    http://answers.microsoft.com/en-us/surface/forum/surfpro4-surfdrivers/slow-stopped-boot-sequence-due-to-touch-keyboard/b4abd175-a2e7-4e61-9dbc-53c16892e1b4
    Or, search this forum for "keyboard folded"
    2015-12-15T18:07:43+00:00
    So this is a different 'failure' mode but might be related. At least I can reproduce it 50% of the time.
    * Keyboard connected and show desktop.
    * shut cover and count 2 seconds
    * press power button and count 2 secs
    * release power and count 2 secs
    * open cover
    Sometimes the display and keyboard backlight come up. Other times only the keyboard back light come one and neither keyboard or touch screen make screen appear. Unit is functioning as holding shift key gives sticky keys high pitched squeak. This mode can be exited by pressing power button twice. Very occasionally I get a strange double beep while holding power button down for 2 secs and then I get in a mode where only a long reset will recover.
    Hope that helps
    2015-12-15T18:33:38+00:00
    In fact an even simpler process causes problems.
    * Remove power and shut cover for 4 secs
    * open cover
    I get one of several responses
    * Keyboard and screen light up
    * Keyboard does not light up but key wakes it and screep up
    * keyboard flashes on and off and then get beep and dis[play driver error an recovered toast
    * keyboard flashes on and off and surface requires long pwer down to reset
    There's obviously something wrong - perhaps a race condition?
    2015-12-15T22:20:30+00:00
    Not sure if I should be glad or sad to see this many people with this problem, since I mainly use the computer docked at home or at the office I have changed the setting to not enter sleep at all while docked, haven't seen the problem as much but this is clearly not an acceptable long term solution.
    Surface Pro 4/i7/16/256
