2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-15T10:18:35+00:00
    2015-12-15T11:48:20+00:00
    Why would MS allow the system to go into hibernate after 120 minutes, which is the default power plan? Are they attempting to break our hard drives?
    2015-12-15T14:15:09+00:00
    I was able to replicate timings which show a repeatable issue with wake up when a SP4 keyboard is attached. I think this is the root cause of many of the problems listed above.
    Test devices:
    SP4 M3 4gb RAM - all MS patches applied using standard update process.
    SP4 keyboard cover
    Test 1.  No keyboard.  Power on from Sleep.  Result is good
    I seemed to get very similar results, except hibernate with keyboard folded back took 60 seconds to logon screen. i5/8GB/512GB.
    However, I cannot be sure it's really sleeping because I was able to get past logon screen without password, although I have that set on required. I'm using Hello/facial, but I tested with screen turned completely away from my face.
    Nice detective work regarding keyboard folded back. I think new thread regarding keyboard results would be a good idea.
    EDIT: After a few minutes after tapping sleep on the power menu a password is required. Seems like when tapping sleep the screen turns off and appears to be asleep, but maybe it only goes into sleep a few minutes later.
    2015-12-15T15:38:48+00:00
    I'm losing patience. It's unacceptable to have to struggle with work-arounds for a device like this. Unfortunately I've been patient beyond the Best Buy return period (I bought it on day one). Does anyone know if Microsoft will take these back even if one were to buy it from Best Buy? At this point I'd rather have a surface pro 3...
    Doug
