2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-14T16:57:47+00:00
    Got my second SP4 back and still having the same issue... The latest display driver update did reduce the like hood of a driver crash but I still get this once a while. However, the sleep issue did not get fix in this update.
    I begin to wonder whether Microsoft is able to resolve the sleep issue soon judging that Intel Skylake is a relative new CPU. If there's a bug in the CPU, then it needs a microcode patch, a BIOS update and subsequent a display driver update. This takes **** a lot of debugging time. Hibernation is a temporary fix but if you keep on hibernating many times per day, you are going to reduce the life of the SSD! The only fix that I know it will definitely work is to treat SP4 like a laptop, shut it down if you don't use.
    Unfortunately time is really an essence and people over here are getting really frustrated and may eventually ended up returning them.
    2015-12-14T23:12:02+00:00
    Finally decided to return my second Surface pro 4.  I cannot believe Microsoft has not fixed this issue yet or at least commented that there is a problem and letting us know they're working on a fix.
    2015-12-15T02:23:08+00:00
    During hibernation it saved an image file of the desktop into SSD. An image file is usually quite large. If SP4 were to hibernate frequently there's frequent big files written to SSD. This will eventually wear down; do note there's a limited write cycle to an SSD but virtually unlimited read . Hibernation is only done as a last resort. Connect standby saved it to memory and put device into deep sleep which is preferred solution
    2015-12-15T10:03:35+00:00
    I purchased 3x surface pro 4, with bags and other paraphernalia. I've owned previous surface products, with the same issue. Microsoft has a track record of not fixing this failure to wake issue and the display driver issue.
    I will be returning all devices for a full refund tomorrow.
    I've come to the end of my tether. As a person who has worked to promote Microsoft and it's products for several decades now and a Silver Partner. I will no longer be recommending Microsoft products. I've had several issues with Lumia Windows Phones (that lose features and have broken hardware after updates),  Windows 10, Office 2016 is no end of trouble and Office 365 has gone from difficult to implement and work with to downright broken (not to mention your complex and convoluted licensing schemes).
    I'm sorry Microsoft but you're focusing too much on your marketing and fluff. You've failed to maintain any quality control on your products and services. You're no longer providing a platform for creativity and business productivity. It's just a mess of frustrations and "work arounds" which don't address or resolve the underlying issue.
    It really pains me to write this and I hope against hopes that you'll change. Yet you're recent intransigence would indicate otherwise.
