2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2017-12-26T23:40:47+00:00
    This is happening to my Surface 4 as well. used to be able to connect the power cord and magically make it come out of sleep. now, nothing. I've tried every trick in the forums and nothing this time. i can hear the drive spin up and access, but no screen anything.
    2017-12-27T10:41:28+00:00
    This is happening to my Surface 4 as well. used to be able to connect the power cord and magically make it come out of sleep. now, nothing. I've tried every trick in the forums and nothing this time.i can hear the drive spin up and access, but no screen anything.
    You can hear the drive spin up? That's amazing!
    2017-12-27T18:44:31+00:00
    You may be hearing the internal fan but these have solid state drives, you can't hear them.
