2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2017-10-15T03:55:06+00:00
    Thanks. I know how to do a soft reset. My post was about trying to find a solution for the cause of the problem. But Microsoft has fixed it in subsequent versions of Windows 10. Thanks again.
    2017-11-06T12:53:43+00:00
    #sod is an infliction we gotta live with. I hibernated and she started displaying all the above symptoms u described.. ohboy.. there gotta be a way out of this, i just got a replacement from microsoft based on a failed ssd,and i lost a lot of information now this! 🤦��‍♂️ So pathetic
    2017-12-11T16:19:28+00:00
    Anyone else is experiencing the 'sleep of death' after the Firmware and drivers update round in December 2017??
    I haven't had to deal with this in over a year, and now it already happened twice in 2 days...
    2017-12-26T19:04:42+00:00
    Yes its started happening to me as well again... did not happen forever now randomly it will happen.  It's a great feature, I love re-doing all my work over and over when it loses it.
    The best part is there is zero info in the eventlogs about it.   Last entry is "entering connected standby"... and that's it.
