2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2017-07-07T17:31:33+00:00
    Hi SteveALee.  What is http://repairavoidancetools.blob.core.windows.net ? It's the download link inside the link you posted.  Since the link you posted is on Microsoft.com, I assume the download link is safe.  Does anyone know if Microsoft owns that URL, or if not, who does?
    2017-07-07T17:36:39+00:00
    That's a very sensible question! Never trust a random link.
    In partial answer see the whois listing for windows.net.
    https://www.whois.com/whois/windows.net
    2017-10-02T14:23:08+00:00
    How do I get my display out of sleep mode?
    2017-10-02T17:33:53+00:00
    If you get no response from the power button, then press and hold the power button for about 20 seconds.  This forces a reset and the Surface should then start up normally.
    Jeff
