2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2017-07-04T06:54:13+00:00
    Is the non-resume issue something Microsoft acknowledges and will correct in a near-future update?  It is really annoying and I hate to have to restart the laptop when my attempt to "hold power button until it prompts you to power off" does not work.
    I hope someone from Microsoft would officially respond and let us know.
    Thanks, John
    2017-07-07T17:11:11+00:00
    Congratulations Microsoft, yet again a Windows 10 update has broken one of your own hardware devices.
    Before the June 2017 updates I could have an external display connected to my Surface Pro 4 via DisplayPort. The SP4 could go to standby and resume fine, both displays would come back on again. After the June 2017 updates, when attempting to resume, the SP4 display flashes briefly for Windows Hello and then goes black. Meanwhile the external display is disconnected! You have to physically disconnect the external display in order to get the SP4 display to work again. See this video.
    There is also the fact that the audio connection usually fails the second time you connect an external display. This has been a fault probably for over a year now and is covered by other threads on this forum.
    All of this means that connecting an external display to a Surface Pro 4 is now an utterly broken experience despite the software and hardware being under the control of Microsoft. There is a total lack of attention to detail and frankly basic testing.
    To add insult to injury it's not possible to stop these frequent and breaking updates from being dumped on my machine.
    2017-07-07T17:17:01+00:00
    My SP4 recently would not restart from sleep. Remenisent of the original 'Surfacegate' problems, the keyboard backlight  would come on but the external display would not show anything (I had set to external only as SP$ cannot handle both internal display and 4K external monitor). I had to do the old long power button reset to regain use.
    I contacted SurfaceSupport on twitter and they suggested this tool which so far seems to have resolved the issue
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/software-repair-tool
    Good luck.
    Steve
    2017-07-07T17:22:01+00:00
    Is this post related to this thread?  Hi, I-am-anderew.  Are you have the sleep-of-death problem characterized by the Surface not responding to a power on and requiring a hard reset in order to get anything shown on the display?
