2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-08-19T18:31:40+00:00
    OK, now that I've given it a couple of weeks, I'll say this:  The *classic* SoD is gone, at least for me, but has been replaced now by new and different (although mercifully, less frequent) failures.  I've had numerous failures to sleep or wake that are different , but still require YAPORRAC (Yet Another Power-Off/Reboot/Relaunch Apps Cycle).
    In most of these cases, the difference is that when I try to wake the SP4, there is no response at all (as opposed to the classic SoD, where it at least lights up the keyboard on a wake attempt...)  Like the original SoD, short sleeps seem OK, but longer ones are much more likely to fail.  At least twice this week, my SP4 has failed to wake in my home office dock in the morning, after putting it to sleep with the sleep button on my keyboard.  Unexplained hard hangs at the Windows Hello/Password/PIN screen are also alarmingly common, requiring YAPORRAC.
    There is also a very serious problem with Bluetooth and USB hardware sleeping, or rather, failure to sleep with USB and BT things connected.  This failure mode is new and curious:  after around 15-20 minutes (I haven't timed it, but will), the system attempts to go to sleep, but apparently, because there are active BT and USB devices, it fails to do so.  As a result, the system repeatedly tries to turn off each of these devices, fails, and turns them on again.  This winds up happening several times a second, preventing the computer from ever entering sleep and resulting in really annoying behaviors like 1) flashing the lights on my Wacom Bamboo tablet (USB) on and off several times a secons, and 2) FAR more annoyingly, playing the "Bluetooth device connected" and "Bluetooth device disconnected" sounds just as often through my Harman/Kardon Onyx BT speaker.  (The latter, BT bug has been around a long time (two years, at least), but it used to trigger the sounds (this is WIndows, NOT the speaker)  just every minute or so (which was plenty annoying enough) - now it's a constant, loud, BEEPBOOP-BOOPBEEP--BEEPBOOP-BOOPBEEP..., apparently as fast as the system can make and destroy BT connections to the speaker.)  This can at least be stopped by any input (keyboard or mouse), but as soon as it tries to sleep again.
    Lastly, as I mentioned before, what half-broken fixes we do have seem to have come at the expense of battery life:  I've tried several times now, and 3-4 hours seems to be the best I can expect now, less than half of what  we were told we should get in battery life on an SP4. (The SP4 is supposed to run longer than the SP3, even though it has a much smaller battery - this was supposed to be the benefit of Skylake's new SP0 power state, which is in reality, a miserable, stuttering, cluster-foxtrot.)  I really like Windows 10, but I'd move to ARM in a heartbeat, given how effectively Intel has created the worst experience ever for SP4 owners.
    So, as I wrote before, SP4 power management under Win10v1607 is better, but nowhere close to fixed - Microsoft still has lots more work to do, and nearly a year on, our PCs still aren't fully capable of being used the way they were advertised.
    2016-08-24T09:53:01+00:00
    After the Anniversary update ... SP4 usually wakes ok, but have had the error that it cannot turn on the camera. This is a new error. I'm almost giving up.
    2016-08-24T23:30:38+00:00
    This may or may not help, but some problems directly involving Surface hardware can be fixed by the following procedure (I have to do this periodically to fix my SP4's occasional loss of contact with its accelerometer/gyroscope, so it can't tell when it's rotated (one cue this has happened is that the "Rotation Lock" button in the Action Center will have vanished, in addition to not responding to rotation...))
    1. Save your work and shut down all programs you care about restoring - you will be rebooting soon.
    2. Right-click on the Start Menu and pick "Device Manager"
    3. Scan up and down to see if there are little yellow "Warning" triangles on any of the hardware devices or families.  (If this is your problem, I'd guess the offending device is "System Devices/Microsoft IR Camera Front"; for the rotation problem, the offender is "Human Interface Devices/I2C HID Device")
    4. If you don't have any warning triangles, you're out of luck, and this procedure won't help you.  Go buy a Guinness and cry in it.
    5. If there is one (or more), then navigate down to the actual device itself (with the warning triangle), right click on it, and choose "Uninstall".
    6. Confirm you want to yank the driver rug out from under the hardware, then reboot  (Windows button/Power Icon/Restart).
    7. When Windows reboots, it will realize it's missing a driver, automatically reinstall it (yes, really!), then come up as normal. (Why it can't just nuke the driver on its own when it realizes it's hosed (warning triangle), and then ask you to reboot so it can fix it, is a deep mystery...)
    8. Do Step 2 again, and ensure the warning triangle in Device Manager is gone.
    9. Restart again (Step 6) just to be safe.  Yes, this sometimes matters.  Go figure.
    10. If you're really paranoid, Do Step 2 one more time, just to be sure it's still fixed. Don't worry, though, something similar will probably spontaneously break in the future, and you'll have to do this whole mess again, because inexplicably, 16 years into the 21st Century, Windows still can't fix these things on its own.  (And people think we're going to have self-driving cars...)
    2016-08-25T07:58:24+00:00
    On the (slightly OT) subject of related wake-from-sleep errors unique to the SP4, I sometimes get application lockups when waking from sleep. Has anybody else seen this? What happens is that the app that was full screen and in focus when the SP4 slept (has happened to both Edge and Maps) is no longer in focus after waking, and doesn't respond to mouse, touch or pen input. However, it repaints and adapts to window size changes, but needs to be shut down from the Task Manager.
    I wonder if this is in some way related to the more serious "sleep of death" issue, since I have only seen this on SP4, and it happens in the same situations as the classic SoD (wake from sleep and user switching). The fact that the application is no longer maximized implies some kind of spurious display state change, but I'm only speculating here. The fact remains that waking from sleep is still a gamble.
    For my part, after the AU, I see the SoD in about 1% of the wake events, which amounts to once every couple of days. I'm now going to replace my device because the touch screen is starting to fail on me (that legendary Surface quality again), so we'll see what that does to the incidence rate.
