2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-08-13T04:22:44+00:00
    I am using Surface Pro 4 i7 with the latest updated Win10 1607. I also encounter the Sleep to Death(SoD) Problem.
    This forum is so long.
    I am attempting to fix this SoD after reading some articles. See if it works. Please notice that I am still testing this solution upon writing this forum.
    Go to Control Panel > Device Manager >
    Turn off the following 2 power saving mode
    1. Univeral Serial Bus Controllers > USB Root Hub > click on it , go to Power Management, disable the SAVE power option.
    2. System Device > Intel Management engine interface > click on it, go to Power Management, diable the SAVE POWER option.
    I will test for several days, see if this works. Feedbacks are welcome to point out this will helps or not. : )
    2016-08-13T17:24:12+00:00
    My system started working fine at some point, maybe a month ago.  Sorry I don't have many details, but I'm on 14393.67, and have all the latest updates.
    No problems waking from sleep any longer.
    Looking at battery life as a bit lower than it used to be.  I'll create a new thread when I know more.
    Not that concerned because my main use of the unit is for development.  Netflix in the evenings, but sure, but mostly dev'ing during the day.
    -thanks
    -e
    2016-08-13T20:00:44+00:00
    This just happened to me, I did not know how to trouble shoot the problem. So I took it to the Connecting Point Store, they could not get it to work either, maybe they did not know the correct trouble shooting steps, anyway they said that it had to be sent in for repair, they did that yesterday.  This is one of the most disappointing pieces of technology ever, in my humble opinion.  Purchased it because for some of my business I need a windows machine.  Otherwise I run only Apple, iMac, MacBook Pro and iPad.  I do not have good confidence in the Surface.  We will see how this turns out.
    2016-08-14T02:38:36+00:00
    I have tested for overnight for Surface Pro sleeping 9 hours , it can wake up after that. Battery drops from 100% to 91%. Seems this setting fix the problem. : )
