2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-08-06T13:07:20+00:00
    AU in this context meaning Anniversary Update.
    Download the Image from https://www.microsoft.com/en-gb/software-download/windows10
    Backup all of your data of course before doing anything and ensure you have the ability to reinstall all your legacy/desktop (win32) apps after a clean install.
    2016-08-06T17:14:27+00:00
    I have the same issues after anniversary update..Damn
    2016-08-09T14:03:38+00:00
    Are you able to resolve this issues..I am also encountering same problem after anniversary updates.
    2016-08-09T14:11:22+00:00
    My surface pro 4 (i5/GB/256 gb) is hanging up if it is idle after anniversary updates..Contacted the customer support three times they failed to fix it..Are there any other solutions apart from clean install?
    Any help is greatly appreciated!
