2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-07-16T16:57:06+00:00
    The latest July Firmware update has improved the SoD problem for me immensely compared to the guaranteed failure I had on every attempt.  Now it seems to happen maybe 1 in every 7 or 8 long duration sleeps.
    However I've seen that there is a much higher power consumption being reported in sleepstudy.
    Another observation is one of the culprits is the USB root device which is the current workaround. And during my tests, I've set this back to the default setting to allow it to sleep. So something is clearly not right with power mgmt in this set of updates.
    2016-07-16T19:04:19+00:00
    Mine has been working for a couple of days too if plugged in. It failed when unplugged...
    2016-07-16T22:30:39+00:00
    My Sleep of Death has returned (1604 machine). The June updates solved my issues but ever since the July updates a few days ago, I've been unable to wake from sleep several times a day.
    Greg (MSFT) - I'm going to try to roll back the updates but please advise which one / driver I should roll back or should I roll back all of them?
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=8bec9a40-f352-42e4-9010-dd0cb6cf80f2)
    2016-07-17T00:37:05+00:00
    This is really curious, I don't know my lot since it is my 4th refurb but my reliability looks opposite to yours since the 7/14 update with no failures in the last two days. However, I am keeping my fingers crossed - I've seen two days without failure before and then the re-emergence of dark wake.  However, I am letting the computer manage the USB Root Hub and still have not had a failure (plugged or unplugged yet). The fact that your SOD was fixed by the June update and broken by the July one whereas others have it seemingly fixed (like me) by the July update points to hardware issues.  I wonder if anyone else with 16XX lots have experienced the same thing as you?
