2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-07T15:12:29+00:00
    I have returned 3 SP4s, the last because of this issue:
    --SP4 #1: rear camera wouldn’t take a picture (later fixed in firmware, but MS Store staff couldn’t reproduce on floor units at the time and swapped it out)
    --SP4 #2: dead pixel. Returned.
    --SP4#3: I lived with this i5/8gb/256gb SP4 for two weeks, during which time it left me hanging TWICE during public presentations (froze once, failed to wake the other time) – humiliating! Returned.
    I had high hopes for the SP4…I never imagined that such a flawed product would be released with such significant technical issues unresolved! Having given MS more than a reasonable opportunity to earn my business, I am headed back to the world of Apple products. I wasted hours trying to get the SP4 to function properly.
    It is interesting to me that the Lenovo Miix 700, which is something of a SP clone also based on Skylake, was not released in November as previously announced. I wonder if they are having similar power state issues and had the wisdom not to release their product until ready. (We will see.)
    2015-12-07T15:33:57+00:00
    Lenovo delaying makes perfect sense if they are experiencing he same issue.  It's hard to say without their input.  The presentation problem can't happen to me so now I'm going to start testing that next.
    Thanks for the heads up.
    2015-12-07T15:58:17+00:00
    Also experiencing all of the same issues.  Will not resume from sleep. Keyboard illuminates but screen does not turn on.  Forces me to do a hard reset and loose all unsaved work.
    I also frequently find my SP4 overheating in the bag because sleep is malfunctioning and battery drained.
    2015-12-07T17:04:36+00:00
    That all sounds very familiar....!
