2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-07-14T23:47:11+00:00
    At least no one from MS has marked this as 'answered' again.  That usually happens as soon as a new firmware update comes out and then we have to complain a lot before they remove the 'answered' :).
    2016-07-15T02:41:31+00:00
    Just received a slew of firmware updates 7/14.  Not sure if these were supposed to come on the 12th update but I've now put the SP4 back to allowing management of the USB.  Will see how this goes.
    2016-07-15T02:49:11+00:00
    Thank you TianjiWu.  Wow, this is much longer than I ever get.  I would definitely say that in sleep mode, previous to this USB change, if I tested how long it would last the best I would ever get was 72 hours.  I never would get 160 hr.  Is there some other settings you have altered?  I have the wifi turned off when sleeping (which made a huge difference).
    Thanks!
    2016-07-15T02:51:27+00:00
    I am curious - are the newer lots after 1613 not seeing this problem at all?  Or is it just not as often?  I have a store close by and a previous technical issue that may allow an exchange.
