2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-07-13T22:29:46+00:00
    That is great news and I am envious.  However, I've experienced similar results to you with previous updates.  I've had sometimes a day or more of no dark wake issues but they always return.  In this July 12 mine failed to wake after the second sleep.
    2016-07-14T17:55:34+00:00
    I took "success" cautiously because I previously saw "success" after cleaning the corrupt image which lasted 1.5 days. This was looked very good but I've just had my first failure since, which means it's not fixed, which means I'm switching back to USB workaround. Ugh!
    2016-07-14T20:40:29+00:00
    6 new filmware updates, feels like a new tablet. will it stays?
    2016-07-14T22:05:41+00:00
    Yes, I have the exactly the same situation. After the July 12 updates, I put the USB Root Hub power saving on. And it worked for 1.5 days or so. So, I got quite high hope this time. But this morning, it didn't wake from sleep! So, I had to turn off the USB Root Hub power saving again...
