2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-07-13T01:51:19+00:00
    According to this: windows 10 update history
    In July 12 update: Fixed issue with some people seeing a black screen instead of the lock screen when resuming from connected standby.
    Just installed and finger crossed, will report back here.
    2016-07-13T02:31:20+00:00
    The tests was done with Surface Book, which is basically identical to SP4.
    The best sleep power I got with USB fix is 600mW, which is around 100hr of sleep with a fully charged SB. In term of SP4, the number should be around 60hr. Pretty acceptable numbers, unless you forgot to recharge someday.
    The sleep power, however, can be as bad as 1000-1500mW, which can leads to a slightly warm-bag, and less than 40hr of sleep with SB, or <24hr with SP4.
    The best number I remember without USB fix is 250mW, which is 270hr with SB, or 160hr with SP4. That is about a week of sleep.
    All the numbers were collected with powercfg /sleepstudy tool.
    2016-07-13T04:12:16+00:00
    Well, I'd like to know who the 'some people' are that the July 12 update fixed the dark wake a.k.a. no wake issue.  I am not one of those.  After the second sleep since updating, I again had the lit keyboard and dark screen.  Had to do a hard reboot again as usual.  So I've turned my USB work-around back on now.  I give up.  MS can't fix this issue and they need to come clean to their customers and explain why and what the resolution is going to be.  I'm on my 4th refurb and even though one of my refurbs was sent to global escalation, the escalation rep didn't even respond to my request for a new 1613 or greater lot unit.  I don't have an MS store nearby and so can't go that route.  Since some people with recent lot numbers have never had this issue, MS needs to step up in a big way.
    2016-07-13T21:46:40+00:00
    Up until now every update has failed to solve this problem for me in the manner described above. However this July 12 driver update seems to have had a 100% success rate with all day testing without power plugged in.
    Usually any sleep longer than 2-4 minutes hadrive black screen and lit keyboard requiring a hard reboot but now I can allow it to sleep 30 mins  to just over an hour  without issue. And on 2 tests I took it to near the default 2hr hibernation threats hold. So 7 out of 7 successo so far.
    Will report back if anything.
    Cheers
