2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-07-06T17:10:47+00:00
    While that is true, I would doubt there is any chance that there will be. A class action suit and if there is some lawyer is gonna get all the money and you'll get $100.
    On another note, I still have my survey out there if you guys had your problem fixed by new hardware or not, please go out and fill out the survey.
    So far I have had about 17 responses out of hundreds of participants in this forum.
    Thx
    2016-07-06T17:15:17+00:00
    I hate to say it but a couple of times is not enough in my experience in order to know that the problem has gotten solved.
    If you are problem free after a week or so, please repost.
    2016-07-07T02:18:20+00:00
    Dear Microsoft people why aren't you listening.  This has been happening to me since I purchased my 4 Pro.  I have purchased a Surface 1, Pro 2, Pro 3 and now a Pro 4 and done the same for my sales team..  I am the definition of loyalty and a valued revenue source.  This is a deal breaker.  I am not upgrading ANY of my guys to the 4 from their 3 if this issue isn't resolved.  We will switch to another platform.
    2016-07-07T02:53:06+00:00
    I hate I ever upgraded from the Surface Pro 2.  The Pro 2 was a good machine.  I just needed a bigger screen and more positions with the kickstand.  So I upgraded to the Pro 3.  That was a big mistake.  The fan would constantly come on, and it would overheat.  After frustration, I purchased the Pro 4.  Thought I made a good purchased.  Instead I upgraded to a device with a different issue.  I now have a device that's not reliable when waking up from sleep.  I don't think I'll be getting another Microsoft Surface Pro.
