2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-06-27T18:10:16+00:00
    Just to provide a different viewpoint, I'm not having any issues with mine after these updates.
    Again, for me, the first fix for the sleep issue, disabling the power saving feature on the USB port, resolved the issue and it's still resolved. None of the updates have caused other issues or changed the sleep issue.
    If you haven't tried it, see if it resolves your issue.
    2016-06-27T23:52:01+00:00
    I have not made this change.  (Nor should I have to - this is supposed to just work.)  In fact, I have made (almost) no changes at all to my system in the hopes that perhaps MS could get the default config working.  (Only three changes:  system is set to never sleep when plugged in (saves my sanity by avoiding dozens of reboots a day and making my SP4 at least usable as a desktop PC), and both Connected WiFi boxes are unchecked in Settings/System/Power&Sleep/WiFi.)
    Because it is a near-default power plan, my system is NOT set to Hibernate at all.  (It's my understanding that it should still do so anyway, when the battery runs low enough while sleeping.)
    Despite all that, my SP4 wedged hard twice this morning - both times after it had been put to sleep with the power button and left sleeping for at least 15 minutes.  (Not sure when the system should *try* to transition from its inital sleep state to a deeper one, but that appears to be the time that things get fouled up.
    Failure to wake after very short sleeps is gone, but failure is 50% or better for any non-trivial sleep on batteries - and I'm fairly certain it's actually worse after the last set of updates.
    2016-06-28T23:46:33+00:00
    I've had the same issue reported on this thread. I bought my Surface Pro4 in Dec 2015 and have experienced this issue recurrently. If I'm working and leave it for few mins, it goes into hibernation. The screen goes black, but see the keyboard keys lit, pressing the power button will not do anything. I've had to reset it pressing and holding Powe button + Volume up for few seconds.
    I've installed the most recent updates as recommended in the feedback, but that will not resolve the problem. I'm ready to return this to the store.
    2016-06-29T15:36:49+00:00
    We need to start doing this more scientifically, guys.
    If we have proof that the issue is not present with the same software and newer devices, we might be able to have strength in numbers, and the understanding that going to the store and getting a replacement will DEFINITELY FIX THE PROBLEM.
    To this end, I created a survey on OneDrive:
    https://1drv.ms/xs/s!AuVy-U2vn\_fUy6g6eERjSr4XlWtuhQ
    Please fill it out?
    -thanks
    -e
