2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-06T13:25:42+00:00
    I can never be sure what is going to appear when I open the Surface Pro 4, especially if it has been plugged in.
    Sometimes I can wake it with touching a key on the key board. Usually I can wake it by pushing the power button for a few seconds.  Sometimes I have to push the power button for a long time.
    Sometimes the screen is just like I left it. Other times I have multiple windows open. Some of them were not open before I put the computer to sleep.
    Today I had a Chrome print screen open and ready to print a 31 page document of computer gibberish. There were about 10 windows open and they would not respond to Xing them out.
    2015-12-06T13:27:38+00:00
    I think my problem may be solved.  I've put it to sleep around 10 times now with no issue waking up.
    Here's what support had me to do.
    1. Run Windows Update and install all the latest updates. You may have to run it many times depending on when you updated last.
    2. Open Device Manager and remove these items under Keyboard.
    HID Keyboard Device
    Surface Type Filter Device
    1. Reboot.
    It's been less than a day of testing but it looks very good so far.  I am using all the default power settings.  I noticed this morning when I opened the keyboard it didn't light up so I pushed the power button and it came out of hibrenate mode pretty quickly.  Remember the default setting is 2 hours after the lid is closed.  I'm am not convinced the issues are over so I'll post back in a day or so with an update.
    2015-12-06T14:08:22+00:00
    So you just deleted the typecover in the device manager. Can you use the typecover after that? Or does the keyboard item in the device manager come back again after you use the typecover?
    2015-12-06T19:51:18+00:00
    I already returned a SP4 because of screen flicker and wake from screen issues. I am wondering now, if I buy another SP4 and the issues are not completely resolved and I decide to return it, will I be able to return it? MS won't "blacklist" me for returning two device? or do you guys think I should wait until these 2 problems are 100% resolved?
    I get the devices with my student account so I am assuming they can see a full history of my purchases.
