2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-06-21T22:34:34+00:00
    My Surface Pro 4 i7 still doesn't wake up after 6/20/16 driver updates.
    2016-06-21T22:37:40+00:00
    Thanks, Greg.  Keep working on it.  The 6/20/16 driver updates did not solve the problem on my Surface Pro 4 i7.  I'm trying different Wi-Fi/sleep settings.  Haven't seen any evidence so far that sleep works on my Surface Pro 4.
    2016-06-21T23:20:46+00:00
    Dear Greg,
    Unfortunately, this 6/20 update did not solve the no-wake-from-sleep problem in my case (SP4 i5/8GB/256GB; LOT number: 1550). So far, the only ways to prevent this no-wakeup problem are EITHER: 1) Replace "Sleep" by "Hibernate" in all the actions (power button; lid, etc.); OR 2) Go to Device Manager => Pick Universal Serial Bus Controllers => Right click USB Root Hub (xHCI) => Pick "Properties" => Pick "Power Management" tab => Uncheck "Allow the computer to turn off this device to save power".
    This Method 2 was suggested by Mike1098 on May 6 in this forum: http://answers.microsoft.com/en-us/surface/forum/surfpro4-surfdrivers/surface-pro-4-screen-wont-wake-from-sleep/aed66dc7-289a-4300-a167-ab8394b7df06?page=193
    For a while (almost two months by now), I have been using Method 2 above with success, which is perhaps more convenient than Method 1. As people discussed around that time, this may not be a true solution though. Since May 6 or so, after each update was released, I checked (with some hope) whether this no-wakeup problem was solved or not by activating (putting the check mark on)  "Allow the computer to turn off this device to save power" above. But so far, whenever I do this, the no-wake-from-sleep issue immediately reappears. So, I have to uncheck that item again.
    Best regards,
    BVPs
    2016-06-22T04:26:28+00:00
    With all due respect for both Barb and Greg I have unmarked this as an answer.  Let's let this update "bake" for a few days and really make sure it's a fix, shall we?
    There are a LOT of very very patient people in this thread and Microsoft can be just a teensy bit more patient before marking this as answered.
    Thank you Susan. Sorry if I got upset, I was just shocked at the issue being marked "answered".
    It sounds like the 6/20 update just further demonstrates that this is a hardware issue. I was pretty nervous letting my SP4 update. After the 2/17 update actually made matters worse for many people I didn't want to ruin my so far perfect new SP4. After an hour with the update my SP4 still works fine, hopefully it won't go bad.
    Pretty clearly, the only solution is a new SP4 and hope you get a good one.
