2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-06-21T21:18:04+00:00
    First, try a two button restart:
    Step 1: Press and hold the power button on your Surface for 30 seconds.
    Next, after your Surface turns back on, check for Windows Updates:
    Step 1: Go to Start and select Settings > Update & security > Windows Update.
    **Step 2:**Select Check for updates. Install any available updates.
    **Step 3:**If prompted, select Restart now.
    For details on Surface updates, please check the Surface update history page.
    Really? This is marked as answering this thread? I mean, yes it get's the SP4 started again, but corrupted files are inevitable if this technique is used often. Marking this as the answer to this thread is another slap in the face to MS customers.
    Perhaps yesterday's update will help the vast numbers of SP4s that have this problem, I don't know. If it does, that would be the answer. But it is certainly too early to tell. The Feb 17 update was supposed to fix everything too; it did not. At this point, the answer to this thread is to return the defective SP4 for a new retail SP4--not a refurb. That is the ONLY solution that as yet has been shown to fix the problem.
    I have a new SP4, and am very happy with it. It wakes from sleep and hibernation each and every time. My first three were garbage.
    If there is ANY integrity here at all, un-mark the above post as the answer to this thread. All you are doing is further angering hosts of unhappy customers.
    2016-06-21T21:36:14+00:00
    Well I can confirm that the newest firmware updates 6/21 have not solved the problem on my SP4.  They installed but that is not an answer since the problem persists on my unit.  This thread is therefore not answered.  Still not waking from sleep, black screen, keyboard lights up and only a hard-reboot works.  I am so very upset.  I have a replacement unit that the MS tech guaranteed wouldn't' have this issue.  I am not happy MS.
    2016-06-21T21:38:30+00:00
    With all due respect for both Barb and Greg I have unmarked this as an answer.  Let's let this update "bake" for a few days and really make sure it's a fix, shall we?
    There are a LOT of very very patient people in this thread and Microsoft can be just a teensy bit more patient before marking this as answered.
    2016-06-21T22:08:50+00:00
    I updated to the latest MS update and then my Surface Pro 4 locked up again. Prior to that I did a download and found the Surface was working GREAT. Now I am at a loss what to do. MS appearently reversed the previous fix
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=ab62d8be-8af4-4281-b26f-c0b1d3302378)
