2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-06-12T12:42:36+00:00
    This is not a fix!!! Every time the computer goes to sleep you have to reboot? What's the point of having sleep in the first place. For me it's worse, every time I lock the computer it's freezes and I have to power down with the two button "solution".
    2016-06-12T20:23:46+00:00
    I received my replacement unit Friday after returning my lot 1548.  It was in a plain cardboard box so is likely a refurb and I don't know the lot number.  I was hopeful but guess what?  Yes after two days the nowake issue is again plaguing my refurb.  I don't understand this because the tech who placed the order guarentted that the unit would be fully tested and would not have this issue as I posted previously.  Yet it does have the issue.  Someone is not doing their job.   I guess if the unit starts up they send it out.  Now I need to go through this again.
    2016-06-12T21:04:45+00:00
    I tried the fix posted...
    https://www.microsoft.com/en-us/download/details.aspx?id=49498
    After a week it looks like it fixed my wake up issues.
    Try the update and see if it helps you...
    I
    2016-06-12T22:02:09+00:00
    The link you mention is to the current drivers and firmware.  I have all current drivers and firmware delivered via windows update.  Can you give more detail on the fix you mention?
