2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-06-10T16:39:28+00:00
    Reading this thread--and my own experience--seems to indicate that the potential for problems is quite high for lot 1610 and earlier, and lot 1611 and later seem to be much better. That lot number could be off a week or two. My lot 1613 SP4 not only wakes perfectly--my three earlier SP4s were horrible--it also performs better and has much, much, better battery life. If you are having issues, please post your lot number, found only on the original box.
    For sure there was some sort of a hardware modification in 2016. Which week, I'm not sure.
    Many have stated that lot 1611 may be the cut-off point - I had my 1550 unit replaced by a 1604 unit and had absolutely no problem with the new unit - I tell my wife how I actually LOVE this device and never had loved a device before as much as I love this device (now that the sleeping issue isn't there) - this is a lot coming from a Linux guy.
    So I put my vote in for the hardware change at least before 1604 based on my personal experience.
    For those who's getting much better battery life - I guess is that it seems that way because the sleep function is actually working correctly?
    I'm also noticing that a number people who's exchanged their device at the Microsoft store is no longer visiting this thread - so advice for all of you that still has the sleep problem - run to your closest Microsoft store and tell them you are not leaving the store without a lot 16xx or later machine. Visit google map to figure out when there are going to be the most number of people in the store - be ready to be insistent and be heard.
    • Peter
    2016-06-10T17:37:25+00:00
    FWIW, mine is lot 1604 and I definitely still have the problem - it wedged hard twice yesterday.
    See previous posts for an outline of my experiences with "refurbished" Surface Pros sent out by the Service group - let's just say that in my considerable experience (spent over two months to get three completely unacceptable refurbs in a row, losing a day or two to rebuild everything each time), Microsoft is utterly failing on the "qwality" of refurbished Surface Pro 3s and 4s - apparently, if it lights up at all, they ship it.
    1st refurb - Hardware problems that kept entire OS from functioning properly.  Extremely unstable (blue/black screens).  Restore/Reset did not help.
    2nd refurb - Looked like it had been through a war - scratched, scuffed, kickstand was bent and broken and would not open past about 90 degrees.
    3rd refurb - Fired it up and it instantly made a chainsaw-like sound - the fan (which ran all the time) was hitting something inside.  People literally came from across the house to see what the noise was...
    Your chances of getting your old SP4 to wake and work correctly are *way* better than getting a quality refurb.  It's really hard to overstate how bad the Surface refurbs are...
    2016-06-10T18:06:04+00:00
    I received my 1609 unit 2 weeks ago. 3 days after receiving it, I started to get the Sleep of Death issue. After some research on the web, I found that many people had corrupted system files from the get go. I ran SFC on the Surface and proceeded to fix all issues using DSIM.
    It was not enough, so I then proceeded to reset my Surface. Problem is still there, happening multiple times a day,
    requiring a reboot every time. Very frustrating.
    I proceeded to disable any power saving option, which is not great for a mobile device.
    I'm using the Surface Dock (newer version) with the latest firmware.
    -Stephane
    2016-06-10T22:09:57+00:00
    Stephane,
    I've been through this as well.  If you'd like, try the workarounds listed in my thread and let me know if they help you:  SP4 Dock Problems Thread
    Just a note, when I say in the thread to run a sleep study, you right-click on Start, open 'Command Prompt (Admin)', navigate to a directory that you can read from, like 'cd C:\Users&lt;username>\Desktop' and then run 'powercfg /sleepstudy'.  You can also add '/duration <# of days>' as well, up to 28.  Go to that directory and it will be a web page called sleepstudy-report.html.  Just open it up in a browser.
    I hope this helps!
