2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-06-09T14:11:00+00:00
    Thanks.  But I take from  your response that MS cannot tell  us which lot our devices are from?  I bought mine in early December, so it sounds like it could fall into the problem category.
    It baffles me as to why there are all of these people complaining yet MS will not deal with the problem.
    2016-06-09T14:31:23+00:00
    They are hoping that those who bought in the batch 15XX either keep quiet or replace the device. Rather than making a public statement on the matter. Chances are the hardware defect has long since been fixed at the factory.
    2016-06-09T14:45:55+00:00
    It's a hardware issue easily fixed by replacing the device (sending broken and receiving a new one).
    (3 working days in Europe)
    Don't waste your time playing with drivers/settings -- just send it and get a new one.
    Just do it :)
    2016-06-10T16:30:02+00:00
    Just do it :)
    My SP4 (15XX) has the same problem (wake -> crash)
    I purchased this device in china and MS only argeed to repair my device, I had to give the device to MS for factory repair.
    This week I received my repaired device, I can draw the following conclusions:
    1.  It's a hardware issue
    After the repair, my device doesn't appear the "wake->crash" problem2.  Repair will cause damage to your device
    After the repair, my device was obviously bent and on the screen i found two significant light leak (not on the edge)
    I don't know how MS does it, but I can't accept such results, it's unfair to me.
