2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-05T03:09:48+00:00
    Already returned mine.  $1,800 to look like a fool in a business presentation?  Pass.
    2015-12-05T21:34:56+00:00
    Adding another comment to this threat in hopes that Microsoft releases a fix for this issue...
    My Surface Pro 4 works perfectly fine otherwise, although this single issue is a BIG issue. I was about to make a presentation yesterday, when this device wouldn't turn on, and I had to embarrassingly take a longer time to restart the device.
    Please fix...if anyone has any other simple fixes in the meantime, I would greatly appreciate it.
    2015-12-05T22:28:56+00:00
    I think the best simple fix in the meantime is to change Sleep settings to Hibernate.
    Although they won't say so in this forum, Microsoft is well aware of the problem and working on a fix. They reported this week that the fix should be available early in the new year.
    http://www.windowscentral.com/microsoft-working-sleep-issues-surface-pro-4
    2015-12-06T13:09:28+00:00
    There are a number of variables in the experiences above - how the device was shut down, how the keyboard was being used, was the device powered or on battery, and especially when people start mashing the buttons on frustration.
    I was able to replicate timings which show a repeatable issue with wake up when a SP4 keyboard is attached. I think this is the root cause of many of the problems listed above.
    I wasn't sure if i should start a new thread - so keeping the results here.  Do you get the same results?
    Test devices:
    SP4 M3 4gb RAM - all MS patches applied using standard update process.
    SP4 keyboard cover
    Test 1.  No keyboard.  Power on from Sleep.  Result is good
    Instant wake up.
    Test 2.  No keyboard.  Power on from Hibernate.  Result is ok
    Dark screen for approx 2 seconds
    Surface logo for approx 5 seconds
    Surface logo and spinner for approx 7 seconds.
    Test 3.  Keyboard attached (folded behind the tablet).  Power on from Sleep.  Result is poor
    Dark screen for approx 12 seconds before logon screen appear
    Just having a dark screen is poor - people are not sure if they really hit the power button so they tray again which leads to confusion.
    Test 4.  Keyboard attached (folded behind the tablet).  Power on from Hibernate Result is UNACCEPTABLE
    Surface logo appears after approx 2 seconds
    Surface logo remains for next 90 seconds!
    Screen goes blank for an instant before the logon screen appears.
