2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-06-07T22:22:53+00:00
    Surface 4 is still having these issues. BUMMPP!!
    2016-06-08T09:02:42+00:00
    And now I'm suddenly starting to see this as well. I had a couple of bug checks related to the IR camera before the big driver update, but now I get a black screen after waking from sleep, followed by bug check every other time I log (using Windows Hello) on it seems. I don't know if this is significant, but so far the crash/black screen has only happened when another user had locked the screen and was still logged on.
    I see a lot of talk about lot numbers? Is that the 4-digit code printed behind the kickstand? In that case mine is #1724. For those interested, these are the bugcheck details:
    BugCheck 14F, {0, 100, 0, 50434c45}
    Probably caused by : pdc.sys ( pdc!PdcpMonitorOnWatchdogWorker+29 )
    Followup:     MachineOwner
    0: kd> !analyze -v
    *                        Bugcheck Analysis                                    *
    PDC_WATCHDOG_TIMEOUT (14f)
    A system component failed to respond within the allocated time period,
    preventing the system from exiting connected standby.
    Arguments:
    Arg1: 0000000000000000, Client ID of the hung component.
    Arg2: 0000000000000100, Win32k did not complete a monitor-on request in a timely manner.
    Arg3: 0000000000000000, The most recent POWER_MONITOR_REQUEST_REASON value for this request.
    Arg4: 0000000050434c45, A value indicating the internal path taken to initiate the request.
    Debugging Details:
    DUMP_CLASS: 1
    DUMP_QUALIFIER: 401
    BUILD_VERSION_STRING:  10586.306.amd64fre.th2_release_sec.160422-1850
    SYSTEM_MANUFACTURER:  Microsoft Corporation
    SYSTEM_PRODUCT_NAME:  Surface Pro 4
    SYSTEM_SKU:  Surface_Pro_4
    SYSTEM_VERSION:  D:0B:08F:3C:03P:38
    BIOS_VENDOR:  Microsoft Corporation
    BIOS_VERSION:  104.1121.768
    BIOS_DATE:  03/01/2016
    BASEBOARD_MANUFACTURER:  Microsoft Corporation
    BASEBOARD_PRODUCT:  Surface Pro 4
    DUMP_TYPE:  1
    BUGCHECK_P1: 0
    BUGCHECK_P2: 100
    BUGCHECK_P3: 0
    BUGCHECK_P4: 50434c45
    BUGCHECK_STR:  0x14F_MONITORON_0x0_ELCP
    CPU_COUNT: 4
    CPU_MHZ: 5e8
    CPU_VENDOR:  GenuineIntel
    CPU_FAMILY: 6
    CPU_MODEL: 4e
    CPU_STEPPING: 3
    CPU_MICROCODE: 6,4e,3,0 (F,M,S,R)  SIG: 82'00000000 (cache) 82'00000000 (init)
    DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
    PROCESS_NAME:  System
    CURRENT_IRQL:  0
    ANALYSIS_SESSION_HOST:  DARTH
    ANALYSIS_SESSION_TIME:  06-08-2016 10:51:03.0353
    ANALYSIS_VERSION: 10.0.10586.567 amd64fre
    LAST_CONTROL_TRANSFER:  from fffff8002c9f19d9 to fffff802b6d5c780
    STACK_TEXT:
    ffffd000224b1a38 fffff8002c9f19d9 : 000000000000014f 0000000000000000 0000000000000100 0000000000000000 : nt!KeBugCheckEx
    ffffd000224b1a40 fffff802b6c5cc59 : fffff802b6fad200 fffff802b6ef6040 fffff80000000000 fffff802b6fad340 : pdc!PdcpMonitorOnWatchdogWorker+0x29
    ffffd000224b1a80 fffff802b6d07b65 : ffffd0010000007b 0000000000000080 ffffe00162491680 ffffe00170ff9800 : nt!ExpWorkerThread+0xe9
    ffffd000224b1b10 fffff802b6d61926 : ffffd00166040180 ffffe00170ff9800 fffff802b6d07b24 0000000000010224 : nt!PspSystemThreadStartup+0x41
    ffffd000224b1b60 0000000000000000 : ffffd000224b2000 ffffd000224ab000 0000000000000000 0000000000000000 : nt!KiStartSystemThread+0x16
    STACK_COMMAND:  kb
    THREAD_SHA1_HASH_MOD_FUNC:  6554c1e422ba11db3654290d3c393f4442aaea94
    THREAD_SHA1_HASH_MOD_FUNC_OFFSET:  030e8e9deb055c9fca4b56340ef04abec30cf624
    THREAD_SHA1_HASH_MOD:  9153fcc24a9debd7fc9e7c503c3c6added606b19
    FOLLOWUP_IP:
    fffff800`2c9f19d9 cc              int     3
    FAULT_INSTR_CODE:  44cccccc
    SYMBOL_STACK_INDEX:  1
    SYMBOL_NAME:  pdc!PdcpMonitorOnWatchdogWorker+29
    FOLLOWUP_NAME:  MachineOwner
    MODULE_NAME: pdc
    IMAGE_NAME:  pdc.sys
    DEBUG_FLR_IMAGE_TIMESTAMP:  571af2a5
    BUCKET_ID_FUNC_OFFSET:  29
    FAILURE_BUCKET_ID:  0x14F_MONITORON_0x0_ELCP_pdc!PdcpMonitorOnWatchdogWorker
    PRIMARY_PROBLEM_CLASS:  0x14F_MONITORON_0x0_ELCP_pdc!PdcpMonitorOnWatchdogWorker
    TARGET_TIME:  2016-06-07T12:46:28.000Z
    OSBUILD:  10586
    OSSERVICEPACK:  0
    SERVICEPACK_NUMBER: 0
    OS_REVISION: 0
    SUITE_MASK:  272
    PRODUCT_TYPE:  1
    OSPLATFORM_TYPE:  x64
    OSNAME:  Windows 10
    OSEDITION:  Windows 10 WinNt TerminalServer SingleUserTS
    OS_LOCALE:
    USER_LCID:  0
    OSBUILD_TIMESTAMP:  2016-04-23 06:04:21
    BUILDDATESTAMP_STR:  160422-1850
    BUILDLAB_STR:  th2_release_sec
    BUILDOSVER_STR:  10.0.10586.306.amd64fre.th2_release_sec.160422-1850
    ANALYSIS_SESSION_ELAPSED_TIME: 1661
    ANALYSIS_SOURCE:  KM
    FAILURE_ID_HASH_STRING:  km:0x14f_monitoron_0x0_elcp_pdc!pdcpmonitoronwatchdogworker
    FAILURE_ID_HASH:  {b02d0e71-ffbb-2e94-5732-48affd4e19e6}
    2016-06-08T12:13:37+00:00
    1724 is the model number.  The lot number is on the original box in small print on a sticker and says date/lot 15xx or 16xx where xx is month batch I think like mine is model 1724 with date lot 1548 which means 2015 April Batch 8.  Someone correct this if I am misinterpreting the month batch.  I used to think it was on the back as well.
    2016-06-08T12:42:15+00:00
    You are right that the LOT is only on the original white box, starting with 15xx or 16xx. However, most of us will agree that the xx refers to the WEEK number, not month-day/lot. It would of course not make sense that a SP4 was manufactured as early as april 2015 and there would be no room for double-digit months or lots.
    So for example mine is 1545, which means roughly the 45th week of 2015, which would be around the first week of November, depending on the calendar in effect. That sounds about right considering that I ordered it in mid-November.
