2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
  1. Deleted
    2016-05-26T22:00:04+00:00
    Honestly and truthfully there is code in this week's firmware.  Will it fix 100% of the issues? Prob not.  But to now at this point in time to say that this issue is 100% due to hardware, I would beg to disagree.
    Susan, I think the point is that it's been 7 months. If they can't fix 100% of the issues after 7 months (or even 100% of the crippling reliability issues), Microsoft needs to take some responsibility for the lemons that they've sold and take actions to make their affected users whole again. Anything else is frankly highly unethical.
    2016-05-26T22:19:04+00:00
    Obviously they aren't going to merely ship unit outs to all Surface pro 4 users.  I just don't believe at this point in time that this is strictly due to hardware issues.  If it was only due to hardware, this driver wouldn't be provided at all.  In my opinion there are software root causes as well.
    2016-05-26T22:22:01+00:00
    P.S. yes I think the time it has taken is excessive.  I also think the push to upgrade from 7/8 to 10 are excessive but as  you can see my opinion doesn't count for much.
    The only thing I will say  - not as an excuse mind you - is that I just feel it's good that Microsoft sees first hand that building solid equipment and getting to root causes isn't easy.  In their role as an OEM, I think they can do better.
