2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-26T19:01:45+00:00
    Happened again to me, unfortunately..
  2. Deleted
    2016-05-26T19:24:17+00:00
    Can you be more specific?  what exactly happened and can you list what third party software is installed on your Surface?/what you are connecting to?
  4. Deleted
