2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-25T22:50:27+00:00
    My apologies I didn't mean you were being disrespectful at all, I was just not seeing the threads and the ones I was seeing about the sleep issue appeared to me to be before yesterday's update.
    Microsoft often won't touch really old threads and ones quite so... um... how shall I say this.... a bit of a hot potato.  I won't be so bold to say that 100% of all issues are fixed in the sleep issue, but like Barb said, that's this one is supposed to help.
    Bottom line, test it out.
    2016-05-26T13:31:34+00:00
    Hi All.
    I've got the same issue. I've spoken with Microsoft and they are working on a fix. In the meantime changing the preferences for what happens when you press the power button/close the lid seems to help. Change all the setting from 'sleep' to 'hibernate'.
    Hope it works for you guys too!
    James
    2016-05-26T13:42:07+00:00
    The fix they are working on came out on Tuesday, have you updated the surface?
    2016-05-26T13:42:46+00:00
    I've gone about 24 hours since installing the 5/24 update, and so far I haven't had any problems at all waking my SP4 from sleep!  This is the first time that I haven't had problems with it waking from sleep, and the longest it's gone with no wake from sleep problems since I bought it back in February.  Let's hope it stays this way!
