2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-25T18:06:06+00:00
    So far (Crossing my fingers) this firmware and software update has resolved the issue on mine.  I'm going to keep shutting down and powering on a few times before I say "it's great".
    2016-05-25T19:24:58+00:00
    My results so far: No wake from sleep issue yet (but as I've only been having that 1-2 times per day, there's still plenty of time for it to occur), with my Surface Pro 3 dock every few minutes my Surface briefly disconnects then reconnects my usb keyboard and mouse, and I still have visual crud in Firefox (although some of the black squares have turned to gray squares).
    Not exactly a home run, but it's probably the first update that didn't make things immediately worse in terms of the no wake thing (although it did make the keyboard and mouse much more unreliable...)
    2016-05-25T20:10:30+00:00
    manually. Thanks for asking.
    I was testing if bluetooth would be missing with hibernation (it usually is); with sleep, it does not wake much, so mostly I have to shut down each time. I try to use it as little as possible for now (as a workaround ... so, without the work, alas).
    2016-05-25T22:34:11+00:00
    Here is the thread : https://www.reddit.com/r/Surface/?count=25&after=t3\_4l0oqv
    I didn't want to be disrespectful, nor understimate  the effort put to resolve the problem, but I frequently check reddit when new updates pop up, and as of now it's mostly been in line with my experience (i.e. both the Feb and April firmware update did not solve the BSOD).
    Since no thread came out claiming the bug was fixed (and it's happened many times during the last few months), and since the only answer on the sleep issue users gave was a ' problem is still there' one, I draw this conclusion.
    Of course, I'll personally test the device: I reported the info for the sake of the discussion, hoping to get other opinions and being proven wrong. I'll let you know if that's the case with my very own SP4 :)
