2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-25T17:02:23+00:00
    Users on Reddit report the problem is not gone, though.
    I'm going to test if that's the case in the following days!
    2016-05-25T17:14:26+00:00
    Got the thread on reddit please?  As while one can never guarantee 100%, a lot of testing and effort went into this so I'd say to all make sure you do your own evaluation and not just rely on "I've heard" if you know what I mean.
    2016-05-25T17:20:55+00:00
    Still having to use the USB workaround because this worked for about 5 mins then failed.
    2016-05-25T17:25:34+00:00
    My SP4 is lot 1548. I had the wake from sleep problem fairly often until the Feb update. Since then I had the issue once (3/27) but did not have to reboot. It has been perfect since. I left all the default sleep settings.
