2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-25T11:27:25+00:00
    same issue. very terrible experience
    I actually just saw a message pop up on the Surface forums when I checked your message.  It said to check Windows Update for some important updates (not related to my question).  I checked and here's what I found.  Looks like some major updates.  Maybe a fix for the problems?
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=1bbe6f97-472d-4cab-bec3-663a50253e42)
    2016-05-25T13:47:16+00:00
    I installed the update last night and enabled regular USB hub sleep and surprisingly it woke just fine in the morning. Before, that would have for sure failed to wake so I hope this is the fix we've been waiting for.
    2016-05-25T14:28:51+00:00
    This has been an ongoing problem for many and the occurrence seems to have increased with the early 2016 update. At this time, my girlfriend SP4 failed to start about 2 out of 3 times.
    Meanwhile the April 2016 updates greatly reduced the problem appearance. Start-up failure now occur about 1 out of 20 times.
    My own SP4 never suffered from this problem. Same model. Basically same software setup.
    There clearly is a slight hardware variation between these devices. Also, the firmware does seem to be at play since the latest version almost fixed the issue.
    We have not installed yesterday's release yet.
    2016-05-25T14:46:10+00:00
    My latest SP4 is lot 1604, which was brand new when I bought it on the ill-fated 2/17 (it immediately updated itself with the new updates released that day, and never ran without them.)  I didn't pay any attention to the lot number of previous units...
    looking through this thread and my own experience, my guess is that you want lot 1611 or greater.
