2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-25T07:39:55+00:00
    same issue. very terrible experience
    2016-05-25T07:46:06+00:00
    I have installed the new update 5/24/16 and disable the USB-Fix after install(it is still active after update).
    Now it seems to work, i tried it more then 10 times, close(wait 30 sec.) and open my keyboard.
    Thank you MS :-)
    2016-05-25T09:35:57+00:00
    I have the 5/26/16 updates done, but for some reason hibernate resulted in the red light coming on and nothing else when trying to wake it. Glad others have success, me not. Awaiting next update (how exciting is that?)
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-05-25T10:40:26+00:00
    How did it get into the hibernate state? Did you manually put the Surface into
    Hibernation or ?
    Barb
    MVP-Windows and Devices for IT
