2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-24T20:13:26+00:00
    Hi all,  I've been having problems the past few months with my Surface but haven't thought to share until today.  It seems somewhat random but if I power on my Surface every once in awhile (always after a clean shutdown) it will power on, fan will kick in low and the type cover will light up, the Surface logo will display, then the display will go dark, not displaying a black screen but completely off.  It will never recover from this state, the only way to get around it is to press and hold Power + Volume up for 15-20 seconds and wait for it to power cycle.
    I've had it do it in a variety of circumstances.
    • When a USB device is attached (Namely a USB NIC or USB headset)
    -The Surface is connected to my docking station (the Pro 3 docking station.  I only have a wireless mouse and a LAN connection on the dock, no other devices.
    -When the Surface is powered on with only the Type Cover 3 attached.  I have not purchased the Type Cover 4 yet and it could be an incompatibility issue?
    The only time I have not experienced this issue when the Surface was properly shut down and no peripherals are attached, including the type cover, then power it on.  Never had a problem doing exactly that.
    I have not disabled the fast boot in Windows 10 yet because if it fixes it I will stop messing with it.  I should not have to disable a default Windows Feature to allow the power to turn on. (Namely people I recommend the Surface to will not understand why you have to turn off the fast boot to have the computer work properly)  It's not a solution, it's a patch fix.
    Not sure if they have faulty firmware or what, I work through it but it's a royal pain some times.
    Any insights would be greatly appreciated!
    2016-05-24T20:55:06+00:00
    My latest SP4 is lot 1604, which was brand new when I bought it on the ill-fated 2/17 (it immediately updated itself with the new updates released that day, and never ran without them.)  I didn't pay any attention to the lot number of previous units...
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-05-24T22:37:50+00:00
    The update rolling out today.. 5/24/16 .. I was told that the management engine update is specifically 'supposed to help with the wake from sleep issue.
    2016-05-24T23:00:59+00:00
    Thanks for the tip! Installing as we speak.
    I've been saying Microsoft needs to do something to revise its management in the wake of this fiasco, but this wasn't quite what I had in mind :).
