I've read a large fraction, maybe most, of the postings here. It does not seem probable to me that this is entirely a hardware problem on specific machines.
Certainly, that could be a factor. But Windows inappropriately handling something that a sizable minority of SP users do better explains why the problem recurs with certain users through many different replacement machines. That also better explains why
it is hard for Microsoft to fix the problem.
I don't claim to be an expert. But it seems to me that Microsoft failure is more related to inadequate diagnostic software than to using cheap hardware components. I too suffer from this wake-up problem but only about five to 10 percent of the time.
So I have mixed feelings about the time it takes MIcrosoft to react to problems like this. I want my SP4 to wake up EVERY time but have also suffered the mess created when inadequately tested fixes are hastily published.
Unfortunately, nearly all software publishers avoid disclosing to users when they are working on a problem and what they are doing. I suspect they are reluctant to acknowledge the possibility of a problem they haven't precisely confirmed. And once they
have precisely confirmed it, the solution is so automatic there's no value in updating users.
So far I'm going to have to disagree with you about it not being hardware driven. I've had four SP4s now. I have set all of them up identically. The first three started having problems in the first 24 hours. This last one--Lot 1613--has been going 3 days
now with no issues. That's not to say it won't have problems two or three weeks from now, but there are some fairly significant differences on this newest SP4. It is clearly faster loading programs. Internet browsers are very noticeably faster. Battery life
is hugely improved. Video playback has gone from about four hours run time to as long as seven hours. (Both at 50% screen brightness.) Normal use has gone from about 6 hours run time to about 9. (50% Brightness.) Chrome crashed regularly on the first three,
it has not crashed yet on the newest device. The fact that this latest device has been waking properly and runs significantly better is almost certainly due to a hardware difference.
I've run the last three SP4 all in the last week, all identical software. Something is markedly different between the latest one and the earlier ones; if it isn't software it seems likely it's hardware. Besides, the battery life improvements alone are well
worth the swap even if this unit eventually starts failing to wake.
If it is hardware MS is not at all likely to advertise that fact. If they did, they'd have to replace every SP4 out there older than lot 1610 or so. Let's face it, most people will live with hibernation or the USB bus workaround. Looking at the mixed reviews
on Amazon, i think MS would be better off in the long run to replace the older devices, but what American corporation actually looks at the long run over short term profits? Very few.
