2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-23T13:12:27+00:00
    I've been using the USB hub fix for about a month now and haven't had a single failure to wake yet and I lose less than 1% of battery an hour when asleep. I've used the USB fix on another machine that had the same problem and it worked for years.
    2016-05-23T13:32:40+00:00
    What is this usb hub fix? How i can do?
    2016-05-23T13:41:04+00:00
    1) Right click on the start button and select device manager.
    2) Go to the bottom and expand "Universal Serial Bus controllers"
    1. Right click on "USB Root Hub (xHCI)" and select properties.
    2. Click the "Power Management" tab and uncheck the box for "Allow the computer to turn off this device to save power"
    3. Click ok, and that should do it! It's been working great for me so far.
    2016-05-23T14:19:27+00:00
    The real fix is to get a new device.
    Even if there's no Microsoft store nearby, you can send it via UPS (free of charge) and get working device within few working days.
    That's what I did and now it works flawlessly without any fixes.
