2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-03T10:19:59+00:00
    I had a similar problem.
    The screen didn't turn on, but the device was on.
    If it's the same problem, you should still be able to blindly log into your account. If that'd work, you can press the dedicated Windows start key on the keyboard. If you then start typing, it will do so in the search field (Cortana is enabled on my Surface, not sure if this is relevant). For some reason, the brightness of the screen will go up when typing in this field.
    Locate the battery icon, click on it and click on the brightness setting and turn it up to at least 50%.
    This should prevent your screen from turning off again. To prevent this issue in the future, you should go to the Settings panel > System > Display and toggle "Change brightness automatically" off.
    I hope this helps.
    2015-12-03T15:45:22+00:00
    To be fair, this isn't really a MS issue, but an Intel issue. This problem affects ALL devices that uses the new Skylake processors, not just Surface Pro's.
    Again, the fix is to install the latest Intel beta drivers, then shut down (not restart) and power back up to reset the hardware. I've confirmed on 4 different SP4 (i7 and i5) that it has completely fixed the problem. None of our Surface Pro users have had a driver crash or wake up problem since the beta driver was installed.
    Until Intel takes that driver out of beta and deliver it as a release version for Microsoft, we won't see this in Windows update.
    I'll also add that we've found another issue that's affecting battery drain during sleep. Turns out that when you close the lid to make the SP sleep, if you accidentally click a key, touch the touchpad, or move an external (BT or USB) mouse before it goes into sleep mode (about 10-20 second process), the SP cancels the sleep and stays awake, draining the battery.
    edit - looks like the latest Windows Update display drivers are in fact the beta drivers that we've been using. Again, make sure you shut down your Surface Pro after install and power back up to avoid any issues.
    2015-12-03T17:21:36+00:00
    Hmmm,
    I installed the beta drivers a few days ago and believed, for a while, that it had resolved the problem. Unfortunately, this morning, I could not wake the machine from sleep, even by using the windows_key-P key combination that has sometimes worked in the past.
    I fear it may not be properly fixed yet.
    Doug
    2015-12-03T18:09:29+00:00
    I also installed the beta driver the other day with initial improvement and then the sleep/wake problem and several new problems occurred so I reverted back to the old driver.
    I still have the sleep/wake problems with the new update.  And the typepad will quit working out of the blue.  And the mouse will just stop working out of the blue................................................
    "one of the most productive devices on the planet!"
