2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-12T01:27:41+00:00
    MS told you it was faulty hardware? Did they say what exactly was causing the problem? There is a MS store near me, might be worth the trip to go have a chat with them. It would take them telling me directly that I need to exchange in order to get me to give up my SB, which by all appearances and functions is working normally with the USB fix. I've had two previous Windows 8 machines that had this same problem out of the box and both were fixed with patches and work correctly to this day.
    I don't think they're going to offer to replace it, if you tell them it's working normally... but if you tell them your device is not waking from sleep intermittently with that specific setting enabled "out of the box / from factory", then I do believe they'll tell you it is a known hardware issue and it should be replaced.
    2016-05-12T03:22:18+00:00
    My unit worked fine as well, for 4 months...it was the February 17th updates, which enabled S0 sleep that exposed the issue. I'm betting that's what caused your unit to start failing. It's doesn't appear to be just some random thing that happens, those February updates are what did it for most people. Either it made your machine better, or it really made it awful.
    2016-05-12T03:30:43+00:00
    People reporting 17xx lot numbers, don't know what the lot # is and are looking in the wrong place. It's easy to think another number like that is the lot number, I almost did. But unless they invented a time machine, no one can have a lot number greater than the year and week. So 2016 week 13 is a 1613 lot number. That's when it was manufactured, perhaps boxed.
    2016-05-12T03:34:14+00:00
    Is someone from MICROSOFT going to chime in here, and offer some advice on page one so folks know to try a few things, and if that doesn't work return the unit?
