2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-11T20:07:28+00:00
    MS told you it was faulty hardware? Did they say what exactly was causing the problem? There is a MS store near me, might be worth the trip to go have a chat with them. It would take them telling me directly that I need to exchange in order to get me to give up my SB, which by all appearances and functions is working normally with the USB fix. I've had two previous Windows 8 machines that had this same problem out of the box and both were fixed with patches and work correctly to this day.
    2016-05-11T20:25:40+00:00
    How can you be sure that the new one is actually fixed though? It took 4 moths for the no wake issue to show up on my unit, who's to say that it won't just happen again on the new units? Using the USB hub fix everything works the way it's supposed to on mine. It enters deep sleep and wakes every time, haven't had a problem with it. Also, this problem has manifested on many different Windows 8 and 10 machines, not just the Surface line. How then can it be fixed with a new lot number of the same device and who's to say MS didn't change something that does the same thing as the USB hub fix but it's not visible to the end user? I guess what I'm saying is there is too much uncertainty with exchanging as a fix and I don't have a single complaint with my SB after using the USB fix.
    So far I agree with this observation in that there isn't any certainty that this wont just appear on new machines with higher lot numbers. I few users have already reported the problem existing on 17xx lot numbers. So far the USB workaround has been way more successful for my SP4 after the tease of the SFC and DISM worked for 36hrs and everything else utterly failed.
    I'm happy to live with this workaround especially since I'm not in the US and also cannot wait an entire month for the Germany based returns center to simply ship out a refurb like we know they do.
    2016-05-11T21:06:42+00:00
    Do what you must do. If you're having the issue, you have defective equipment. Believe what you want though.
    For what it's worth, I ALSO do not believe it is a matter of getting a specific lot number. I do however believe that regardless of which lot # you have, this sleep issue is a known hardware issue by microsoft and it seems to be random and in all lots. Microsoft did tell me it was a hardware issue, that it was a known issue, and without question they gave me a new device. I didn't say anything except, "im here because i have a sleep issue with this device, it will not resume from sleep, but keyboard lights up, system is up-to-date".
    2016-05-11T21:10:23+00:00
    I walked in, told them I was there because my surface pro 4 i7 16gb will not resume from sleep state about 40-50% of the time "keyboard lights up but nobody is home".. have to hard reset.. device is up to date.
    The MS guy behind the counter, was not the person helping me... but he shouted over her talking to me, saying "just replace it, its a known hardware issue, if it's up to date and still having the issue". They verified it was up to date, factory reset the device and gave me a brand new one.
    This new device is not experiencing the issue. My previous device, is experiencing the issue.
    I am aware that the hardware could fail in the future, but the fact that its not experiencing the issue now with the same conditions and same software proves their point. The issue is related to failing hardware, whether you experience it now or later is besides the point.
