2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-11T11:11:13+00:00
    Interesting...brand new device, lot 1613, sleeps fine. But when I run the energy report, I do get a USB analysis error
    USB Suspend:USB Device not Entering Selective Suspend
    This device did not enter the USB Selective Suspend state. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping.
    Device Name USB Input Device
    Host Controller ID PCI\VEN_8086&DEV_9D2F
    Host Controller Location PCI bus 0, device 20, function 0
    Device ID USB\VID_045E&PID_07E8
    Port Path 7
    2016-05-11T11:28:38+00:00
    Nice thought but we don't have them in the UK!
    2016-05-11T12:09:02+00:00
    I had that opinion, until today. No i don't think, they're "that bad". I think their stupid phone support might be the most awful in the history of awful phone support.... but if you can hop on over to the Microsoft store somewhere I think you'll be pleasantly surprised.
    At this point, it's pretty clear that some units work without issue, while others continue to have issue. Some people have had luck returning their device and getting a new device that does not experience the problem.
    You can continue to have a headache and keep hoping for software updates that might or mask your actual hardware problem, or you can exchange it for a new one before your warranty runs out. If it happens again, you better believe i'll be in the store asking for another because this shouldnt be a problem, and some units do not have this issue. Go to the store.
    I agree, with you if Microsoft cannot fix it what makes the people on this thread think they can?? Just send it back and be done with it, there was no store in my state so I called support and they shipped me a replacement and it has been working trouble free for a few weeks now.
    2016-05-11T13:24:05+00:00
    How can you be sure that the new one is actually fixed though? It took 4 moths for the no wake issue to show up on my unit, who's to say that it won't just happen again on the new units? Using the USB hub fix everything works the way it's supposed to on mine. It enters deep sleep and wakes every time, haven't had a problem with it. Also, this problem has manifested on many different Windows 8 and 10 machines, not just the Surface line. How then can it be fixed with a new lot number of the same device and who's to say MS didn't change something that does the same thing as the USB hub fix but it's not visible to the end user? I guess what I'm saying is there is too much uncertainty with exchanging as a fix and I don't have a single complaint with my SB after using the USB fix.
