2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-11T03:58:29+00:00
    Quick question for those of you with a working machine and a broken machine (but not with the "don't let windows turn off usb controller" enabled). When you run powercfg /energy do you get an error relating to a USB device refusing to enter sleep state?
    Also, we've passed 200 pages! Congrats! I didn't think we'd make it here, but Microsoft is just that bad!
    2016-05-11T04:36:02+00:00
    I had that opinion, until today. No i don't think, they're "that bad". I think their stupid phone support might be the most awful in the history of awful phone support.... but if you can hop on over to the Microsoft store somewhere I think you'll be pleasantly surprised.
    At this point, it's pretty clear that some units work without issue, while others continue to have issue. Some people have had luck returning their device and getting a new device that does not experience the problem.
    You can continue to have a headache and keep hoping for software updates that might or mask your actual hardware problem, or you can exchange it for a new one before your warranty runs out. If it happens again, you better believe i'll be in the store asking for another because this shouldnt be a problem, and some units do not have this issue. Go to the store.
    2016-05-11T06:39:19+00:00
    "I truly do not want to replace or exchange my surface pro 4 and lose out on my glass screen protector, or have to completely reinstall and configure every application I've already installed."
    I've had the same thought too about my device. Luckily, I bought a glass screen protector from Amazon that had a lifetime warranty - when I was taking the screen protector off, it broke in one corner. I emailed them about this and they sent me a code to use on Amazon for zero charge. Many screen protectors have a lifetime warranty, see if yours do also.
    As for reinstalling the software, it's really not that painful. Between file history, dropbox and onedrive, I got all the data back and no big deal reinstalling everything - it was worth doing this to get a device that works as it was meant to.
    FYI, I exchanged a lot 1550 unit for a lot 1604 unit at the MS store - no sleep issues for 2.5-wks. I am not using the USB workaround. And don't bother with the sfc fix, it may give you a proper sleeping for a couple of days at most, but it's a tease.
    • Peter
    2016-05-11T10:58:11+00:00
    The stores are fantastic, they just need more of them. I suppose this will happen if Microsoft's consumer brand gets more popular.
