2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-11T02:06:43+00:00
    They won't, I already had them installed as I'm on the Insider Release Preview Ring, and had them on the old device too.
    2016-05-11T02:08:15+00:00
    Don't get your hopes up at all, I'm completely convinced it's the hardware. It USB workaround is ok with you, just stick with it and be happy. You're not going to get it fixed unless you get a new machine
    2016-05-11T02:16:04+00:00
    Did you not read my above post? I already returned it and got a new device... different lot #...?
    So tonight I took my surface pro 4 i7 16gb 256gb lot #1609 back to best buy... they were more than willing to exchange it or return it, but the only lot # they had was exactly what I already had. I took the device to the Microsoft store immediately after and exchanged it for another. The people at the Microsoft store were well aware of the issue and said it was a "known issue". They were helpful, and at this point after some conversation I do not believe it makes a difference which lot # you have. I believe it is an issue with the hardware itself.
    This device is from lot # 1610
    USB root hub xhci still has box checked for "allow computer to turn off this device"
    All power settings set to factory settings, and all drivers and windows updates performed.
    I'll post back and keep checking the thread... hoping I never experience the dreaded "won't wake from sleep" bug anymore
    2016-05-11T02:33:20+00:00
    I have been following this thread for a while.  I have the same issue.  Will someone explain where to find the lot number?
