2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-05-10T13:31:10+00:00
    I truly do not want to replace or exchange my surface pro 4 and lose out on my glass screen protector, or have to completely reinstall and configure every application I've already installed.
    I hope they come up with a software fix/ patch for this
    For what it's worth, mine is a surface pro 4, i7, 16gb 256gb,  lot # 1609
    I'm going to try installing todays updates and disabling the "work around". I'll post afterwards.
    2016-05-10T13:55:54+00:00
    Do not accept a replacement device. If you just recently got this device, return it to best buy, and get a new one. I just returned my device that I got on October 26th from Best Buy and started exhibiting this very issue after the February 17th update. I finally went to the Microsoft Store and they gave me a brand new unit that DOES NOT exhibit this behavior. It was definitely hardware, as I had wiped the previous devices completely and reinstalled. I didn't even need my original receipt from Best Buy. I had the original box, pen, and charger and they gave me a new unit. I kept my original Type Cover, which has been fantastic and held up great. My original device was in Mint Condition and was lot 1541, the new device is lot 1613. Good luck to you, but don't accept the broken hardware device, even if the USB fix works.
    The above was my experience as well. Many weeks into new device and it's working as expected and has been great. Except one situation when docked and in sleep, the device got very hot and the fans were running high all night. I don't dock to often but it seems there may be standby issues while docking.
    On another note, shocking news: Customer Satisfaction with Tablet Devices.
    MS #2?!?! They are also making nice profits off the Surface devices. This means they are selling a lot and tells me we must be a relativelysmall audience with these problems. Kind of baffling though.
    As some others have said, KEEP going back until you get a working device or let the thing go. Newcomers, you're not going to find a silver bullet here.
    To the other person who tried the Twitter route, I tried this hundreds of posts ago and it didn't take very well. Must not be a lot of Twitter users on here, but I agree it would be more productive than continued posts in this forum.
    #SurfacePro4 #nowake
    2016-05-10T14:51:09+00:00
    I have an appointment today I just scheduled with the Microsoft store to look at the device. I will let you know how I make out there.
    What lot # should I be looking for???? I have 1609 currently and it is definitely still experiencing the issue.
    2016-05-10T15:09:46+00:00
    Well, I can confirm that the updates released on the 9th did not fix the no wake issue, so back to the USB hub fix for me.
    You know, when I first got my SB I knew there were bugs, but I imagined that somewhere inside of Microsoft Headquarters there was a room full of frenetic action. Premier programmers working around the clock on the issues, furiously typing away and passing printouts of line graphs back and forth while a serious looking man with his sleeves rolled up draws circles around things on a white board and draws arrows to other things.
    "Surely this team can solve any issues the SB/SP4 is having!" I thought. Months later, I now picture it to be a dimly lit wood paneled room with a single 1990's tower and CRT manned by Napoleon Dynamite who just looks up pictures of Ligers all day.
