2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-03T01:53:12+00:00
    It may be fixed. Microsoft released a driver update today. I have installed it and it seems to resolve the problem for me.
    http://www.windowscentral.com/microsoft-releasing-new-display-driver-surface-pro-4?utm\_medium=slider&utm\_campaign=navigation&utm\_source=wp
    2015-12-03T01:54:42+00:00
    I have had and still have the same awful impression about Microsoft's nonchalance (seemingly anyway, but perhaps these poor guys there have so many hundreds of even bigger and badder bugs to fix that they will rather let their reputation sink into the negative side of zero, than fix an error of this severity.)
  3. Deleted
    2015-12-03T05:08:34+00:00
    The driver crashing  may be fixed, but the wake up from sleep issues isn't. Driving me crazy. Just hard reset, reinstalled everything including cumulative and firmware. Still has the issue. I'm starting to think this "upgrade" from my sp3 was a big mistake.....
